Куратор темы: Solo
Начать новую тему Ответить на тему  [ Сообщений: 2344 ]  На страницу Пред.  1 ... 86, 87, 88, 89, 90, 91, 92 ... 118  След.
Номер сообщения:#1761  Непрочитанное сообщениеДобавлено: Пн ноя 26 2018 22:53
Список резьб, используемых в велосипеде:
АНГЛИЙСКИЙ (ОПРЕДЕЛЕН АВТОМАТИЧЕСКИ)РУССКИЙАНГЛИЙСКИЙНЕМЕЦКИЙ
РУССКИЙАНГЛИЙСКИЙУКРАИНСКИЙ
2.2mm x 56 tpi Common 2mm spoke threading
3mm x 0.5mm Dropout adjustment screws, some derailleur hardware, accessory hardware
4mm x 0.7mm Some derailleur limit screws (DIN standard)
4mm x 0.75mm Common derailleur limit screw (JIS standard)
5mm x 0.8mm Many uses on bicycles, including derailleur wire pinch bolts/nuts, disc rotor mounting bolts, fender and racks mounts, water bottle cage bolts, and others
6mm x 1mm Many uses on bicycles, including brake caliper mounting bolts, brake pad bolts/nuts, some fender racks, some brake adjusting barrels
7mm x 1mm Some handlebar binder bolts
5/16 inch x 24 tpi Front hubs, solid axle, less expensive bikes
8mm x 1mm Square-type crank bolts, front solid axle hubs, suspension system hardware
8mm x 1.25mm Stem hardware, stud type crank nuts, suspension hardware
8mm x 0.75mm Chainring bolt
9mm x 1mm Front hubs, quick release, Asian manufacturer
9mm x 26 tpi Front hubs, Campagnolo®
3/8 inch x 24 tpi Some solid axle bike, including coaster brake
3/8 inch x 26 tpi Solid rear axle
10mm x 1mm Most quick release rear axles, derailleur mounting bolts, brake lever adjusting barrels
10mm x 26 tpi Rear axle, quick release, Campganolo®
12mm x 1mm Some spline crankset bolts
1/2 inch x 20 tpi Pedal threads, one-piece cranks
9/16 inch x 20 tpi Pedal threads- common three piece cranks
14mm x 1mm Oversized frestyle axles
15mm x 1mm tpi Crank bolt, Octalink® and ISIS Drive®
1-inch x 24 tpi Threaded headsets, one-inch standard
1-1/8 inch x 26 tpi Thread headset, 1-1/8 inch standard
1-1/4 inch x 26 tpi Thread headset, 1-1/4 inch standard
1.37 inch x 24 tpi Bottom brackets, ISO/English/BSC, and threaded freewheel hubs
1-3/8 inch x 26 tpi Bottom brackets, older “Raleigh” three speeds
36mm x 24 tpi “Italian” threaded bottom brackets
2,2 мм x 56 тpi Общая резьба с резьбой 2 мм
3 мм x 0,5 мм Регулировочные винты отвода, некоторые аппаратные средства переключения передач, дополнительное оборудование
4 мм x 0,7 мм. Некоторые винты ограничения скорости (стандарт DIN)
4 мм х 0,75 мм Общий ограничительный винт переключения передач (стандарт JIS)
5 мм x 0,8 мм. Многие используют на велосипедах, в том числе болты / гайки для проволочных зажимных болтов, болты крепления ротора диска, крепления крыла и стойки, болты для бутылок с водой и другие
6 мм x 1 мм. Много применений на велосипедах, включая болты крепления суппорта тормозных суппортов, болты / гайки тормозных колодок, некоторые стойки ограждения, некоторые тормозные колодки
7 мм x 1 мм Некоторые болты крепления руля
5/16 дюйма x 24 tpi Передние ступицы, твердая ось, менее дорогие велосипеды
8 мм х 1 мм Квадратные кривошипные болты, передние упорные оси, оборудование подвесной системы
8mm x 1.25mm Stem аппаратное обеспечение, шпилька кривошипные гайки, подвесное оборудование
8 мм х 0,75 мм Цепной болт
9 мм x 1 мм Передние ступицы, быстрый выпуск, азиатский производитель
9 мм x 26 tpi Передние ступицы, Campagnolo®
3/8 дюйма x 24 tpi. Какой-то сплошной мотоцикл с мостом, включая кабриолет
3/8 дюйма x 26 тpi Твердая задняя ось
10 мм x 1 мм Самые быстроходные задние мосты, болты крепления переключателя, рычаги регулировки тормозного рычага
10 мм x 26 tpi Задняя ось, быстрое отключение, Campganolo®
12 мм x 1 мм Некоторые болты с крепежными болтами
1/2 дюйма x 20 tpi Педальные нити, цельные кривошипы
9/16 дюймов x 20 tpi Педальные нитки - обычные трехкомпонентные кривошипы
14 мм x 1 мм Негабаритные оси фристайл
15 мм x 1 мм tpi Кривошипный болт, Octalink® и ISIS Drive®
1 дюйм x 24 tpi Резьбовые гарнитуры, стандарт 1 дюйм
1-1 / 8 inch x 26 tpi Нитевая гарнитура, стандарт 1-1 / 8 дюймов
1-1 / 4 дюйма x 26 tpi Нитевая гарнитура, стандарт 1-1 / 4 дюйма
1,37 дюйма x 24 tpi Нижние кронштейны, ISO / английский / BSC и резьбовые ступени свободного хода
1-3 / 8 дюймов x 26 tpi Нижние скобки, более ранние «Raleigh» три скорости
36 мм x 24 tpi «Итальянские» резьбовые нижние кронштейны
Номер сообщения:#1762  Непрочитанное сообщениеДобавлено: Вт ноя 27 2018 00:27
встретил в сети фото вот такого трайка.
к сожалению, больше инфы не нашел.Изображение
Номер сообщения:#1763  Непрочитанное сообщениеДобавлено: Вт ноя 27 2018 07:11
Наверное, это все же квад.
Номер сообщения:#1764  Непрочитанное сообщениеДобавлено: Вт ноя 27 2018 09:14
нет это трайк. слева одно колесо бОльшего диаметра, на него и привод
Номер сообщения:#1765  Непрочитанное сообщениеДобавлено: Вт ноя 27 2018 12:12
Причём с двумя управляемыми колёсами :)
Номер сообщения:#1766  Непрочитанное сообщениеДобавлено: Вс дек 02 2018 13:10
(я честно стырил с интернета)
Как выучить незнакомый алфавит.
Возьмем для примера грузинский алфавит. Почему именно грузинский? Ну, просто потому, что он почти никому не знаком.
Итак, допустим, вам надо выучить грузинский алфавит. Тогда вы просто берете и читаете:
Максим Солохин, «Король и Каролинка»
(текст под спойлером, ибо большеват)
В тридевятом царстве, в тридесятом государстве жил–был я.
(ა=а)
Я жил с Пაпой и Мაмой. Мои Пაпა и Мაмა очень сильно любили другა. Тაк сильно и стрაстно, что чაсто ссорились. И это неудивительно: при тაкой–любви люди невольно стремятся к полному единомыслию и тяжело переживაют всякое рაзноглაсие. Во всяком случაе, Мაмა тяжело это переживაлა. ა рაзноглაсий у них было много. Нაпример, когдა я родился, Пაпა нაзвაл меня Вячеслაв, ა Мაмა нაзвაлა меня Влაдислაв. Но Пაпა любил Мაму сильнее, и в конце концов, кაк прაвило, уступაл ей. Потому восторжествовაлა в конце концов Мაминა редაкция. ა звაли меня просто: Слაвик.
(ო=о)
Я хოчу рაсскაзაть здесь пოучительную истოрию, кაк меня сделაли вოлшебникოм. Вოлшебствო у меня не ოт хოрოшей жизни — кაк гოвოрится, с вოлкაми жить, пო вოлчьи выть. Вოოбще–тო я челოвек прაвოслაвный, и кოлдოвაть мне неприличнო, нო ребятა мოегო двოрა стაли ოткрოвеннო пოбაивაться меня пოсле тოгო, кაк ოднა девოчкა сოшлა ოт меня с умა. ოбычнო, кოгдა гოвოрят, чтო ктო–тო ოт кოгო–тო «без умა», пოдрაзумевაется любოвь. Срაзу предупреждაю: никაкოй любви у нაс не былო и в пოмине.
(ე=е, э)
В чეм–тო я винოвაт, кოнეчнო. Я пოнимაю, чтო ოт слухოв тაк прოстო нე ოтмაжეшься. Мнოгим нეოхოтა рაзбирაться в жизни всეрьეз, их впოлнე устрაивაют схეмы. Я нაпишу всე кაк былო — ктო хოчეт, тოт пოймეт. Нო срაзу прეдупрეждაю: истოрия дოвოльнო стрაшнეнькაя и вეсьмა зაпутაннაя. Слაбოнეрвных и сильнო зაнятых прოшу нე бეспოкოиться.
(ნ=н)
Мოи уნивეрситეты
Игрა пოдхოдилა кონцу и пო лოгикე вეщეй дოлжნა былა зაвეршиться пოбეдოй мოეгო вეличეствა. Зა ეти ნეмნოгиე дნи, прოвეдენნыე мნოю в ნოвოй кოмпანии, я ужე пოкрыл свოю гოлოву ნეмეркნущეй слაвოй ნეпрეвзოйдენნოгო «Кოрოля». ეдиნствენნოე, чтო ნეскოлькო ოмрაчაлო мოи пეрспეктивы, ეтო тაиნствენნაя ნაстя.
(ი=и)
ნაстя вოოбщე былა пეрсონოй, мягкო гოвოря, ნეოбычნოй. Я в тოт мოмენт ეე ეщე ნი рაзу ნე вიдეл — ნაстя, гოвოрят, былა в ოтъეздე. ნო вოт, вчეрა вეчეрოм ონა, ნაкონეц, прიეхაлა, ужე рაсспрაшიвაлა Вიку прო мენя ი зაявიлა, чтო сეгოдნя იгрაეт. Рეбятა гოвოрიлი прო ნაстю кაк прო ნეвეсть кაкую вაжნую птიцу.
(ტ=т)
— ონა всეгдა выიгрывაეტ, — скაзაлა Вიкა. — С ნეй იгрატь бეспოлეзნო.
— Чტო, ოчენь хოрოшო იгрაეტ? — удიвიлся я.
— ნე ტო слოвო. Я ტეбე гოвოрю, с ნეй იгрატь бეспოлეзნო.
— ეტო ტოчნო, — скაзაл Сანя ტрოიцыნ. — ონა прოсტო чуეტ, гдე кტო. Всე рაвნო ნე спрячეшься.
Рაз ტაк, рაссудიл я, зნაчიტ, лучшე ნე рაспускატь бოйцოв. ა ტო пეрეщეлкაეტ всეх пოოдინოчкე.
(რ=р)
Зაдაчა бოйцა пროсტაя — ნაдო увიдეტь сოпერნიкა пერвым. Увიдეტь ეгო რანьшე, чეм ონ ტეбя увიдიტ. Увიдეტь — в смыслე пროсტო зაмეტიტь, ოбნარужიტь. Я ტуტ пოкა чტო ნე ტოлкую ო мიсტიчეскოм ВიДენიი, ო скრыტოй лიчნოсტი ი пროчეე. В იгრე всე пროсტო. Зაдაчა — увიдეტь пროტიвნიкა რანьшე, чეм ონ ტეбя увიдიტ, вოტ ი всე. У взროслოгო ტуტ ნეტ ნიкაкიх пრეიмущეсტв пერეд мაлышოм. Мაлышу дაжე лეгчე спრяტატься.
(ს=с)
ნაчინაეტსя იгრა в «Кოროля» ს глოбაльნых пრяტოк — пრячуტსя вსე ოტ вსეх. ესлი ტეбя зაмეტяტ რანьшე, чეм зაмეტიшь ტы, ტო როлი Кოროля ტეбე ужე ნე увიдატь кაк სвოიх ушეй. Пოпასტьსя ნა глაзა зნაчიлო лიшიტьსя шანსოв.
ეტიм уტროм я სвოй шანს ნე упуსტიл. ნაчაл я ტაк.
Выйдя იз квარტირы, кრაлსя пო пოдъეзду. ოსტანოвიвшისь ნა вტოროм ეტაжე, дოлгო пრისлушიвაлსя, ნე пრячეტსя лი кტო–ნიбудь вნიзу, ნე სпуსкაეტსя лი Вიкა სвერху. Былო სოвსეм ტიхო. Выждაв мინуტ пяტь, რეшიлსя იдტი вნიз.
(ლ=л)
ნიкაкოй ოпასნოსტი я в ტოტ мოмენტ ნე ოსოзნაвალ. Пროისхოдილა ნეвინნაя дეტსкაя იгრა. ნო у мენя ужე სერьეзნო სოსალო пოд ლოжეчкოй. Вსякაя იгრა хოროшა იмენნო ტეм, чტო в кაкოй–ტო мოмენტ пრიхოдიტ вдოхნოвენიე. ტы пერესტაეшь იгრატь ი ნაчინაეшь жიტь იгროй. Зა пოსლეдნიй гოд я იгრალ ტაк мალო, чტო ტეпერь у мენя быლ явნый იзбыტოк ნერასტრაчენნოгო вдოхნოвენიя.
(ვ=в)
Мეжду пროчიм, я ოчენь რანო пონяლ, чტო ვзროსლაя жიзნь — ეტო ტა жე იгრა. Пოчეму ლюдი ტაк სტრასტნო гონяტსя зა ტეмი цელямი, кოტორыე ონი пერეд სოбოй სტავяტ? ვეдь ვნაчალე ონი საмი, пო სვოეму жელანიю, სტავяტ пერეд სოбოй ეტი цელი. Кაзალოსь бы, ვსე ლიшь уსლოვნოსტь! Чეму ოгორчატьსя ი ო чეм რაдოვატьსя? ნო кოгдა пრიхოдიტ ვдოхნოვენიე, зაбыვაეшь ო ტოм, чტო იгრა — ეტო ტოლькო იгრა.
Пოдოйдя к ვыхოду, я ვдრуг ოщуტილ სტრაх. Я ნე мოг ოტкრыტь дვერь, ტაкაк зა дვერью мენя ждალა ოпასნოსტь. Гოვორяტ, ვзროსლыე ინოгдა ოщущაюტ სмერტელьნую ოпასნოსტь кოжეй. ნო ოпასნოსტь дოლжნა быტь იмენნო სмერტელьნოй, ინაчე სლაбый гოლოს «шესტოгო чуვსტვა» ნე пროбьეტსя სкვოзь ტოლსტую кოжу ვзროსლოгო. У რეбენкა кოжა ტონьшე. ონა дაжე სლიшкოм ტონкაя. Мы, дეტი, чასტო пугაეмსя ნა пуსტოмესტე, кოгдა бოяტьსя ნეчეгო.
(კ=к)
Я ვერნуლსя ნა пოლ–ეტაжა ვვერх ი ნაчალ ოსტოროжნო ოбოзრევატь ოკრესტნოსტი чერეз ოკნო пოдъეздა. ვსე пრეдыдущიე дნი ინტуიцიя у мენя дეйსტვოვალა ისпრავნო, ი სტრაх ვოзნიკალ ტოლьკო ტოгдა, კოгдა быლო дეйსტვიტელьნო ოпასნო. Чესტნო гოვორя, я ი საм ეტოму удივლяლსя! კაკ будტო зა пოსლეдნიй гოд, пროვეдენნый ვ мონასტыრე, у мენя пოяვილისь კაკიე–ტო სვერхъესტესტვენნыე სпოსოбნოსტი. Шესტოე чуვსტვო.
(მ=м)
ნეдარომ მესტნыე რეбяტა ужე дერжალი მენя зა მასტერა. Я пოчტი ვსეгдა სტანოვილსя კოროლემ. ი ნა სეй რაз ვნуტრენნიй гოლოს მენя ნე ოбმანуლ — чერეз მინуტу ვ კრონე дერევა ვ ოტдალენიი ოტ კოзыრьკა пოдъეздა я ოбნარужილ хოროшო зამასკიროვანნую зასაду. ვ удოбნოй რასщელინე მეжду дვух სტვოლიკოვ კლენა სიдელ სანя ტროიцыნ. Пოვოзივшისь ს зაдვიжკოй, я бესшуმნო пრიოტკრыლ фორტოчკу ი ვпოლгოლოსა კრიკნуლ:
— Хა!
ეტო ოзნაчალო ვыსტრელ. Зაдაчა бოйцა пროსტა — уვიдეტь пროტივნიკა ი კრიკნуტь «хა». კტო კრიკნуლ пერვыმ, ტოტ «убილ» пროტივნიკა. Дაжე ინტერესნეე: ნე пროსტო убილ, ა სдელალ ეгო სვოიმ ვოინომ. ა სამ იз пროსტых ვოლьნых სტრელკოვ ოдნიმ მაхომ სტალ კოროლემ.
(პ=п)
სანя ნაპრяжენნო зავერტელ гოლოვოй, პыტაяსь уვიдეტь ტოгო, კტო ეгო პოдსტრელილ. ნო მენя სკვოзь რაздელяющую ნას ლისტვу, дა ეщე ვ ტემნოტე პოдъეздა, ონ ვიдეტь ნე მოг.
— სიдი ნა მესტე, — სკაзალ я სკვოзь фორტოчკу.
სანя ნაკონეц уვიдელ მენя.
— პოკა სიдი ნა მესტე, — პოვტორილ я, სლოжივ რуკი რуპორომ. — Хოროшო სიдიшь. Я სპущуსь ვნიз ი буду პრიტვორяტьსя პროსტыმ სნაйპერომ. ა ტы სლушაй ი სმოტრი.
სანя зაуლыбალსя ი კივნуლ. კოროლემ ემу ужე ნე სტატь. Бოეц მოжეტ ტოლьკო პერეхოдიტь იз–პოд ვლასტი ოдნოгო კოროლя ვო ვლასტь дრугოгო. ნო იгრა ოტ ეტოгო ნე სტანოვიტსя ნეინტერესნოй. ნაოбოროტ, ს პოяვლენიემ «კოროლეй» ი ნაчინაეტსя პო–ნასტოящემу ინტერესნაя იгრა. ნაчინაეტსя ინტრიгა ი კოვარსტვო.
(უ=у)
პოдსტრელენნый სნაйპერ იз რაзრядა ვოლьნых სტრელკოვ პერეхოдილ ვ რაзრяд სოლдატ კოროლя. ტეპერь я быლ კოროლь, ა სანя — მოй სტრელოკ. ვ ეტოй იгრე ნიკოгო ნე უбივალი, მენяლასь ტოლьკო როლь იгროკა. ი ეტო ნაдლეжალო ისპოლьзოვატь, ვეдь კრომე ნას ს სანეй პოკა ნიკტო ნე зნალ, чტო я უжე — კოროლь. ი чტო სანя უжე — ნე ვოლьნый სტრელოკ, ა მოЙ ვოინ.
ვნაчალე — ტოლьკო ვნაчალე! — იгრაюტ ვსე პროტივ ვსეх. ვნაчალე ვსე ტვოი ვრაгი, ი იгრატь ოчენь პროსტო. Яსნო, чტო ნაдო дელატь. ნო «კოროლя» პრიдუმალ Дეд. ა ეгო зაдუმკი პროსტы ტოლьკო ნა პერვый ვзгლяд.
ვოოбщე–ტო ლюбაя იгრა — ეტო პრიტვორსტვო. ნო ეტო პრიტვორსტვო бეз კოვარსტვა! ოбычნო როლი ვ იгრაх быვაюტ პონяტნы ი чეტკო зაдანы. ა ვ «კოროლე» სამოე ტრუдნოე быლო — ეტო სოოбრაзიტь, კტო კაკუю იгრაეტ როლь. კტო კოროლь, კტო სნაйპერ, კტო дრუг, კტო ვრაг. ოტ ეტოгო зავისელო, чტო ნაдლეжიტ дელატь. პოროй ვოзნიკალი პრяმო ნემыსლიმыე гოლოვოლომკი, чემ–ტო სმუტნო ნაპომინავшიე მნე жიзნь ნა ოбრატნოй სტორონე ლუნы. ა я ი зატეяლ რასსკაз ოб ეტოй жიзნი.
(დ=д)
იзოбრაжაя ოбычნოгო სტრელკა, я ოსტოროжნო ვыгლяნულ იз დვერი პოდъეзდა. ს ეტოй ტოчკი სანя быლ პოчტი ნეзამეტენ, ა სამ я быლ კაკ ლადონი. ესლი бы я ვышელ ეტიმ პუტემ, быტь бы მნე სანინыმ სოლდატომ. ნო მედლიტь быლო ნელьзя — я უსლышალ, კაკ ლიфტ, იდუщიй სვერхუ, ოსტანოვილსя ნა ვტორომ ეტაжე, ი чьი–ტო ოსტოროжნыე ლეгკიე ნოгი დვინულისь კ ვыхოდუ. ვსე быლო яსნო. Я პო–ვзროსლომუ რეшიტელьნო ოტვორილ დვერь ი ტვერდოй პოსტუპью ვышელ ნარუжუ. დვერь зა მნოй зაхლოპნულასь, я პოკაзალ სანე зნაკომ — პრიгოტოვьსя სტრელяტь. ა სამ სტალ პრიტვორნო კრასტьსя ვდოლь სტენы, პოვერნუვшისь бეззაщიტნოй სპინოй კ ვыхოდუ იз პოდъეзდა.
ოსტოროжნო პრიოტკრыვ დვერь, ვიკა უვიდელა კრადუщეгოსя მენя ი ნემედლენნო კრიკნულა:
— Хა!
ვიკა პოვერილა, бუდტო я — პროსტოй бოეц, ი პოდსტრელილა მენя პერვოй. ნო დლя მენя ეტო ეე «хა» быლო სოვერшენნო ნეოპასნыმ: დელო ვ ტომ, чტო კოროლя ნელьзя პროსტო ვзяტь ი პოდსტრელიტь. კოროლь ნეუязვიმ დლя «ვыსტრელოვ». ი სამ კოროლь ტოжე ნიკოгო პოდსტრელიტь ნე მოжეტ: კოროლი ნე ვოююტ, ა ტოლьკო რასპორяжაюტსя. კოროლя зაщიщაюტ ეгო ვოინы. Чტოбы კოროლя «უбიტь», ვრაгუ ნეოбхოდიმო зადეტь ეгო რუკოй. ნო რუკოй зადეტь მენя ვიკა ნიკაკ უжე ნე მოгლა, პოტომუ чტო ეე ტუტ жე პოდбილ სანя:
(ბ=б)
— ვიკა, хა!
ტეპერь ვიკა სტალა ვასსალომ სანი. სტატь კოროლემ სანя უжე ნე მოг, ნო ონ ვპოლნე მოг სდელატь ვ მოემ კოროლევსტვე ნეპლოхუю კარьერუ.
გილოცავთ!
За это сообщение автора -=LT=- поблагодарили: 3 Jozef (Чт дек 27 2018 07:50), O-Witte (Вс дек 02 2018 14:18), virage (Вс дек 02 2018 23:12)
Номер сообщения:#1767  Непрочитанное сообщениеДобавлено: Пт дек 07 2018 21:21
немного исторических фото:
где-то 1890-е года
реклама 1900 год
Билл Гейтс на своём любимом велосипеде, 1970 год
Номер сообщения:#1768  Непрочитанное сообщениеДобавлено: Вс дек 09 2018 17:35
Номер сообщения:#1769  Непрочитанное сообщениеДобавлено: Вс дек 16 2018 13:55
Благодарил (а): 35 раз.
Почему пожилые люди медленно читают? статья в "науке и жизни" https://www.nkj.ru/news/35082/
Возрастное замедление чтения происходит независимо от нашего желания.
С возрастом люди многое начинают делать медленнее, в том числе медленнее говорить и читать, и это происходит даже у неврологически здоровых людей. Но почему языковые процессы замедляются у пожилых? Потому ли, что для понимания текста приходится медленно читать? Или же человек осторожничает, боясь совершить ошибку, или же экономит когнитивные усилия и адаптирует нагрузку к своим нейрофизиологическим возможностям.
В эксперименте сотрудников Центра языка и мозга НИУ ВШЭ участвовали добровольцы из двух возрастных групп: от 18 до 24 лет, и от 59 до 81 года. Они читали предложения, которые появлялись на экране слово за словом – чтобы перейти к каждому следующему слову, нужно было нажать кнопку. Так можно было понять, какую скорость чтения предпочитает тот или иной человек. На следующий день скорость появления слов задавали уже сами экспериментаторы, и в одном случае она равнялась средней скорости чтения, а в другом её увеличивали в два раза.
Изначально молодые люди выбирали для себя максимально возможную скорость, которая позволяла понимать прочитанное. Пожилые, как и ожидалось, читали медленнее молодых. Но если бы пожилые люди специально занижали скорость чтения, то они бы лучше выдержали принудительное повышение скорости. Иными словами, когда тех и других заставили бы читать в ускоренном режиме, пожилые участники делали бы меньше ошибок – потому, что они изначально экономили силы.
Однако, как говорится в статье в Psychology and Aging, на ускоренном режиме и молодые, и пожилые ошибались одинаково. Иными словами, пожилые люди вовсе не специально замедляют скорость чтения. По словам младшего научного сотрудника Центра языка и мозга ВШЭ Анна Лауринавичюте, замедление чтения, вероятно, носит неизбежный характер, и происходит оттого, что мозгу нужно время для лексического доступа и грамматического анализа. Исследователи рекомендуют читателям старшего возраста спокойно относиться к своей естественной скорости чтения и не пытаться «насильственно» её увеличить: возможно, что именно замедление помогает обеспечить высокую правильность понимания текста.
По материалам пресс-службы НИУ ВШЭ.
Автор: Юлия Смирнова
Источник: Наука и жизнь (nkj.ru)
9 Декабря 2018г
За это сообщение автора AleksejR поблагодарил: -=LT=- (Вс дек 16 2018 20:08)
Номер сообщения:#1770  Непрочитанное сообщениеДобавлено: Вс дек 16 2018 20:17
Немного о вере в безопасный атом :twisted:
еще немного инфы:
на самом деле это совместная станция, а реальность такова:
но, вообще, подумать стоит:
:twisted:
Номер сообщения:#1771  Непрочитанное сообщениеДобавлено: Вс дек 16 2018 22:24
Смысл в том, чтобы дождаться стабильного ветерка нужного направления, и устроить преднамеренный взрывчег безо ффсяких ракет? :?:
Номер сообщения:#1772  Непрочитанное сообщениеДобавлено: Пн дек 17 2018 11:42
такой смысл приходит в больную голову только тебе.
Номер сообщения:#1773  Непрочитанное сообщениеДобавлено: Ср дек 19 2018 21:55
немного о сварке...
За это сообщение автора -=LT=- поблагодарил: Warlus (Ср дек 19 2018 22:27)
Номер сообщения:#1774  Непрочитанное сообщениеДобавлено: Сб дек 22 2018 22:33
как называют Деда Мороза / Санта Клауса в разных странах.
(снова большая картинка)
https://cdn.jpg.wtf/futurico/c6/4e/1545484777-c64e01bf4df39c88208b99eb2550dd6b.jpeg
Номер сообщения:#1775  Непрочитанное сообщениеДобавлено: Пн дек 24 2018 20:39
немного о сварке...
И ещё немного.
А вот это мне больше всего понравилось:
Номер сообщения:#1776  Непрочитанное сообщениеДобавлено: Вт дек 25 2018 16:04
Главное, чтобы из титана варили без присутствия этой красоты!!!
Номер сообщения:#1777  Непрочитанное сообщениеДобавлено: Чт дек 27 2018 01:15
знание английского не нужно и так видно :twisted:
[youtube]http://www.youtube.com/watch?v=x6XeELc3QH8[/youtube]
Номер сообщения:#1778  Непрочитанное сообщениеДобавлено: Чт дек 27 2018 17:14
Нашёл на параллельном форуме...
[youtube]http://www.youtube.com/watch?v=0i2nLQ5HK5k[/youtube]
Зачем весь этот цирк с минибайками? Народ смешить? Он и так над нами ржёт (или с пустым взглядом хмуро отстраняется). :|
Уделили бы внимание суточным гонкам Сергея, а также рекордам на стримлайнере в Неваде!!!
Ни слова не сказали...
Номер сообщения:#1779  Непрочитанное сообщениеДобавлено: Чт дек 27 2018 18:05
Дашевский - великий человек!
Номер сообщения:#1780  Непрочитанное сообщениеДобавлено: Пт дек 28 2018 22:11
аккумуляция интересных видео в уходящем году (лигерадов нет, но лисопеды есть)
[youtube]http://www.youtube.com/watch?v=ukrhwlH83a8[/youtube]
понравившейся сюжет (они пронумерованы) подробнее можно посмотреть здесь https://www.youtube.com/playlist?list=P ... sP4HWqAncD
зацените велодорожки из этого видео https://www.youtube.com/watch?v=9Z77qDqvzNk
[ Time : 0.858s | 20 Queries | GZIP : On ]
